Problems Upgrade Common Services 3.0.4
I?m trying to upgrade Common Services to the versi?n 3.0.4, but the installation always stops at 10%.
Have I to do anything special?. I have stopped the CiscoWorks Services before the upgrade, I have closed all the application,...But nothing. Only one thing, I am doing the upgrade through Terminal Services.
Best Regards
Thanks !!!!
Nuria
Silver
Re: Problems Upgrade Common Services 3.0.4
Hi Nuria,
Open a DOS shell and issue the command:
net stop crmdmgtd
Once you get the prompt back, open up the task manager and go to processes.
If any of these processes are listed, kill them manually:
sm_server
sm_authority
brstart
Maybe one of them is still active.
I assume you are running Windows. I use terminal services in Administrator Mode. This may be not supportd by Cisco but it is not denied, while using Application mode is denied.
In Partition C: the CW Installation creates a logfile. If an actual one is there please post it.
Best regards,
Frank
It doesn?t work. The log is:
DEBUG: MoveFileData, script for db is C:\Documents and Settings\adminib021\Local Settings\Temp\1\pft6.tmp\cdone_a.ins
DEBUG: file d:\CISCOW~1\setup\cdone_a.ins exists
DEBUG: file d:\CISCOW~1\setup\cdone_a.001.ins exists
DEBUG: file d:\CISCOW~1\setup\cdone_a.002.ins exists
DEBUG: file d:\CISCOW~1\setup\cdone_a.003.ins exists
DEBUG: file d:\CISCOW~1\setup\cdone_a.004.ins exists
DEBUG: file d:\CISCOW~1\setup\cdone_a.005.ins exists
DEBUG: file d:\CISCOW~1\setup\cdone_a.006.ins exists
DEBUG: file d:\CISCOW~1\setup\cdone_a.007.ins exists
DEBUG: file d:\CISCOW~1\setup\cdone_a.008.ins does not exist
DEBUG: package db, copying script cdone_a.ins from C:\Documents and Settings\adminib021\Local Settings\Temp\1\pft6.tmp\ to d:\CISCOW~1\setup\cdone_a.008.ins
DEBUG: MoveFileData, script for cwhp is C:\Documents and Settings\adminib021\Local Settings\Temp\1\pft6.tmp\cdone_a.ins
DEBUG: package cwhp, already processed cdone_a.ins as cdone_a.008.ins
DEBUG: MoveFileData, script for dcr is C:\Documents and Settings\adminib021\Local Settings\Temp\1\pft6.tmp\cdone_a.ins
DEBUG: package dcr, already processed cdone_a.ins as cdone_a.008.ins
DEBUG: MoveFileData, script for mdf is C:\Documents and Settings\adminib021\Local Settings\Temp\1\pft6.tmp\cdone_a.ins
DEBUG: package mdf, already processed cdone_a.ins as cdone_a.008.ins
ERROR:An error occurred during the move data process: %d
Component: mdf
File Group:
File:
INFO: action action_endInstall, begins at 14:02:49
MAIN: CleanUpInstall START at 14:02:49
INFO: finishing installation, ABORT_FLAG is set
MAIN: Installation complete at 14:02:49
INFO: Finished at 14:02:49
NOTE: Unable to Grep for ERRORS & WARNINGS in the log file.
NOTE: Please go through the log file manually for ERRORS and WARNINGS.
Thanks!!
Best Regards!!!
Nuria
this looks similar to CSCsc95307
The workaround is the following:
Before upgrading follow the below steps
1) Stop the Ciscoworks Daemon Manager using net stop crmdmgtd
2) Go to NMSROOT/bin (NMSROOT is where CiscoWorks is installed)
3) Rename dmgtd.exe to dmgtd1.exe
Now start the installation. The installation should proceed without error.
After the successful upgrade of LMS2.5.1 from mega patch, delete the renamed file
dmgtd1.exe.
If the deletion fails, reboot the server and delete it again.
davistan, is correct. I had the same problem. However I did not rename any of the files. All I did was set the "Ciscoworks Daemon Manager" to "Manual", reboot the server and the install was successfull. After the install you have to set it back to automatic and reboot.
Mike
OK, It works if you rename the file.
Thanks very much.
Best Regards.
Nuria
117
