Problems Upgrade LMS2.5.1 to 3.0
Bigs problems with this upgrade.
First:
You can see the different step with the file LAN_Upgrade_LMS251_to_LMS30_Cisco.pdf.
2. RME > Config > out of Sync >. you can see RME-Out-of-Sync-Failed.JPG. No difference on the equipment but the LMS shows lots of difference.
3. CS > Add Equipment. No visibility for the new device on the map VTP. When i restart the server, we can see only the equipment on the layer 2. VTP map configuration is deleted.
4. CS > Device Update > On the link RME on this page. We can see error tomcat - http 500.
Thanks a lot for your help.
David
Network engineer Axians
1 REPLY
Silver
Re: Problems Upgrade LMS2.5.1 to 3.0
You can migrate to LMS 3.0 using either of these two methods:
Local Migration, which is the process of installing LMS 3.0 on top of the existing LMS version on the same machine and migrating the data into it.
Or
Remote Migration, which is the process of installing LMS 3.0 on a different machine and migrating the backed up data into it.
For details on migrating data for all applications to LMS 3.0, see
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.0/data_migration/guide/dmg_win.html#wpxref60380
85
