Problems with DCR
Scelo
Hi guys,
I upgraded LMS 3.0 to LMS 3.2 and started Daemon Manager but the web server didn't get started, when i check process most of them didn't get started and as a results iT can't comunicate with DCR.
5 Replies 5
Joe Clarke
Post the output of the pdshow command.
Attached is the pdshow and some other files taken from LMS 3.2 (WIN 2003) installation. Your help in this regards shall be highly appreciated.
More logs, i checked under event viewer and found nothing interesting to forward to you.
Does "Self Test Fail to query cmf.DbVersion, Error: Invalid user ID or password (DBD: login failed)" result to "{cmfDbMonitor} cannot connect to cmf db"?
If so, will i be right to re-initialize my database as it may be corrupt ("{cmfDbMonitor} cannot connect to cmf db")?
Will reseting the database password help in this regards?
I re-initialized DBs and it seems to have been a fix. However, DFM wasn't sending our alerting messages and had to restart daemon manager.
