Problems with upgrading IOS using Ciscoworks
I am having this strange problem while attempting to upgrade IOS for Cisco 3745 Router using Ciscoworks .
I get the following error message.
Fetching image from Image Library (for System Software Upgrade):
c3745-advipservicesk9-mz.123-16.bin --> d:\PROGRA~2\cscopx\temp\s3b0.1
Image retrieved from library.
Loading image file to flash device : c3745-advipservicesk9-mz.123-16.bin --> flash:c3745-advipservicesk9-mz.123-16.bin
The rcp transfer has failed. Trying tftp protocol now ...
Error loading image to Flash.
Error Info Code: '4159'
Message: 'Device Error: The copy to/from flash operation failed.'
Action/Reason:
'Probable Cause: Flash copy failed with return code of
copyUnknownFailure.
Recommended Action: Retry the operation. If the problem
persists, contact your technical support representative for
assistance.'
Device has been unlocked from exclusive access.
Image Upgrade Failed
The image that I am trying to copy to flash is about 21 MB.
I am able to pull ( backup) image from the same device. The existing image size is 17 MB.
I know there was (or maybe is ) a limilation in Cisco TFTP for copying a image greater than 16 mb but I do not think this to be problem as existing image is being backed up.
What should I try next ( RCP is disabled on CiscoWorks) or can this problem be resolved by applying some CW patch ?
My CW details are given below.
CiscoWorks Common Services with SP2 ver 2.2
RME 3.5 with IDU update 11.0
Vijay Sequeira
134
