process status of LMS2.5
I am config. LMS2.5 on window server2003
the process report is attached with mail
please check it, becouse a no. of services is not running properly, and shows server is down,
  • Network Management
Re: process status of LMS2.5
do you have added any device???
I am not sure but I think you didn?t. You should add at least one and manage it in Campus and RME and DFM. As well you should configure all the backup processes and purge jobs you think you need or LMS requires. After that you can came back and look at the process table. You will understand that some processes depend on how you have configured LMS. So if some possible features aren?t enabled the correspondig process states "never started" and others will start on a schedulded basis.
READ these guides and you will know more afterwards:
Quick Start Guide:
http://www.cisco.com/en/US/products/sw/cscowork/ps2425/products_quick_start09186a00805af28a.html
http://www.cisco.com/application/pdf/en/us/guest/products/ps2425/c1244/cdccont_0900aecd8026ee8d.pdf
MArtin
10 devices is already added in CS-device management, but in device summary list no object is appeared why?
in LMS2.5 when open Ciscoworks Common services--server--admin--job browser or resource browser it shows jrm server down or is inaccessiable
how i can solve this
processes shows jrm is running
If you get a message indicating jrm is down, but the jrm process is up, this can be due to one of a few things. For example, hostname changes, ACS integration, and Common Trust User misconfiguration can all cause connections to jrm to fail.
Given the large number of process failures, I suggest you open a Service Request with the TAC. There are a few logs that need to be analyzed here as well as some server parameters (e.g. CiscoWorks Service startup parameters).
May i config. this LMS2.5 again on the same server with same licence key
You can reinstall LMS 2.5 on the same machine or a different machine using the same license key. However, if you have two versions of any of RME, Campus Manager, DFM, or IPM running, then you will need two licenses.
265
