provisioneer.exe LMS
I have a trouble with process provisioneer.exe. There are used CPU about 99%. I am afraid it isn't correct, I don't know what is doing this process.
Does anybody know what is the problem here?
Thank you
sarka
Re: provisioneer.exe LMS
This process is associated with CiscoWorks Assistant. Simply reboot the server, and the problem should go away.
I too am seeing this process take over the CPU at times. Is there a better solution than "reboot the server"? Since you pointed out that it is for the CWA I have been simply killing the process.
What is causing this and what can be done to prevent?
Please start a new thread for your issue.
202
