07-29-2007 11:34 PM
I have dectetd that files in difffiles directory are not deleted. Are this files not deleted with the purge jobs in RME?
LMS:2.5.1
RME:4.0.4
07-29-2007 11:43 PM
You are hitting the bug CSCse88215 documented at http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCse88215
The bug will be fixed in RME v4.1 and the current workaround is to delete those files manually.
Hope this helps....
-- Pushkar
07-30-2007 12:31 AM
Thanks for the info
can all files in this directory be deleted? and I have first to stop dmgtd?
07-30-2007 08:15 AM
Yes first stop the daemon and then delete all the files in the directory and restart the daemon.
-- Pushkar
