Community Member
pushing images through software distribution
I am using LMS 3.0.1 unable to push Image through software distribution.I have a particular image in software repository.Selected the image & the device to be pushed.But the job is failing & giving the default errors.then I enabled approver now its waiting for approval then saying the job rejected.
can u pls revert asap?
Silver
Re: pushing images through software distribution
Default errors?
Elaborate.
I never used the job approval stuff.
Cheers,
Michel
Community Member
Ok I removed approval list & tried.
Still failed I am pasting the error msg pls have a look at it.
JOB ID - 1073 SUMMARY
Device Name : 10.10.2.75
Software upgrade result - Failed
Total number of devices scheduled for upgrade : 1
Number of devices upgraded : 0
Number of devices failed : 1
Total time taken for Job - 3 Minutes 16 Seconds
Status of Job - FAILED
Starting Job: ID - 1073
Job Started At : Wed Jan 30 11:40:10 AST 2008
Job running on : netserver2
Upgrade Mode : Parallel
Reboot Mode : Parallel
Protocol Order for Image Transfer : TFTP,SCP,HTTP,RCP
Protocol Order for Config-operations : TELNET,TFTP,SSH,RCP,HTTPS
Total number of device(s) to be processed : 1
Processing Device : 10.10.2.75
Start Time : Wed Jan 30 11:41:16 AST 2008
Device is locked for exclusive access.
The supported protocols for image transfer are: TFTP,SCP,RCP
Connecting to the device using SSH...
Connected successfully.
Require Flash Erase to load the new image...
Trying to backup flash:config.text from the device using TFTP
Copying flash:config.text to C:/PROGRA~1/CSCOpx/tftpboot/rep_sw_707373005864592238 using TFTP.
Copying config.text from flash to tftp://86.36.71.22/C:/PROGRA~1/CSCOpx/tftpboot/rep_sw_707373005864592238
Failed to import the image config.text from device.
See C:\PROGRA~1\CSCOpx\files\rme\jobs\swim\1073\10.10.2.75_telnet.log for the output from the device on which the image transfer failed.
Trying to backup flash:config.text from the device using SCP
Copying flash:config.text to C:/PROGRA~1/CSCOpx/temp/rep_sw_2975621515454163354 using SCP.
Copying config.text from flash to scp://86.36.71.22/C:/PROGRA~1/CSCOpx/temp/rep_sw_2975621515454163354
Trying to backup flash:config.text from the device using RCP
Couldn't create an empty temp file in rcp-specific directory.
Cause: SWIM0145: No RCP User configured in Cisco Works Server .
Set up the rcp user (Default is cwuser) in the 'Common Services->Server->admin->system preferences' screen.
Image Copy Operation Failed
Device is unlocked.
Device Upgrade Result : Failed
End Time:Wed Jan 30 11:42:17 AST 2008
Job Ended At : Wed Jan 30 11:43:26 AST 2008
Silver
I thought an RCP user was configured on the fly....maybe try to configure one as suggested.
Search the help for "rcp user" and then check the chapter "Configuring rcp"
Cheers,
Michel
Blue
What does C:\PROGRA~1\CSCOpx\files\rme\jobs\swim\1073\10.10.2.75_telnet.log say?
454
