Community Member
PVM 1.0 on Redhat - i386 installation error
Hi All-
I am installing PVM 1.0 with Redhat Linux 4 Enterprise on an Intel system with 2 GB RAM and a 2.6GHz P4. I immediately receive the error: 'PVM is supported only on i386 hardware platforms.'
Following through the installation scripts, I found that this error occurs as a result of the sys_min_req.sh platform test using the Linux 'uname -i' shell command. The interesting thing is that if I invoke that same command at the shell prompt, I receive the appropriate 'i386' response that the script is expecting to 'pass' the test. The script indicates an error anyway. Ideas?
Thanks!
1 REPLY
Silver
Re: PVM 1.0 on Redhat - i386 installation error
PVM is only supported on Red Hat Enterprise Linux Version 3and 4, not on other version . Here is the documentation.
http://www.cisco.com/en/US/docs/net_mgmt/performance_visibility_manager/1.0/release/notes/pvmnote.html#wp16934
It would appear that the Server Assistant RHES4 install limited the size of the directories, partitionas etc causing the problems.
96
