08-25-2006 08:06 AM
I am trying to find a MIB for the ISR routers (2801, 2811, 2821, 3825 and 3845) which will allow me to query the equivalent value as: show policy-map interface or somnething along these lines.
I believe I may need either/or;
CISCO-QOS-PIB-MIB
CISCO-CLASS-BASED-QOS-MIB
Which i can find for the non ISR range on the Cisco MIB locator download tool page, but not for the ISR routers.
Does anyone know if these are available or what specific MIB I should use and where I can download it.
Thanks in advance,
Lee.
Solved! Go to Solution.
08-25-2006 08:24 AM
I used the MIB Locator tool from this link and could see the MIB's supported on these ISR routers including the CISCO-CLASS-BASED-QOS-MIB
http://tools.cisco.com/ITDIT/MIBS/servlet/index
It is even specific to IOS and featureset for the devices
If you want to down these mibs you can go to:
www.cisco.com/public/mibs and click on v2 at the bottom
08-25-2006 08:24 AM
08-29-2006 02:10 AM
I have found what I need using these links.
