Webcast-Catalyst9k
QoS on Ethernet Network Modules
Does Ethernet network modules support QoS features such as CBWFQ,LLQ & WRED.I havent been able to find it on the net as it doesnt say explicitly(www.cisco.com/go/3600/).Its becauz i want to connect two 3640 routers using WIC-1ENET & testing QoS on it.Otherwise Im sure it will work if I use Serial or E1 modules.
Pls guide.
Thanx
1 REPLY
Silver
Re: QoS on Ethernet Network Modules
Yes, all the latest ethernet modules support QOS and QoS features such as CBWFQ,LLQ & WRED will work as expected if configured correctly.
135
