04-07-2006 09:34 AM
We want to install QPM 3.2 on a Win2000 Server with terminal services enabled in remote admin mode. We know it is recommended that Common Services 2.2 is installed on a Win2000 server without terminal services enabled. Has anyone done this before? Does it work well?
04-07-2006 10:18 AM
It will work fine as long as Terminal Services is disabled during the installation.
04-07-2006 10:26 AM
Hi nhabib,
Thanks for the reply. Do you mean if we disable Terminal Services during the installation and enable it later on, we will be fine to use QPM?
04-07-2006 10:29 AM
Yes.
