Community Member
Question mark in Ciscoworks LMS 3.2 for common services
Dear friends,
I am getting a question mark in common services for all the devices viz. 6509, 7609, 3750 etc. However, these devices show up correctly in CM.
I am not sure if the reason is because i added devices into CS using Bulk Import?
Here are the software versions:
1. LMS 3.2 27 Apr 2009
Rows per page: 100 200 300 400 500           Go to page:   of 1 Pages
Products Installed
Showing 1-10 of 10 records
    Product Name    Version With Patch Level   Installed Date
1.  Campus Manager 5.2.0 27 Apr 2009, 11:14:32 GMT+03:00
2.  CiscoView 6.1.9 27 Apr 2009, 11:14:33 GMT+03:00
3.  CiscoWorks Assistant 1.2.0 27 Apr 2009, 11:14:33 GMT+03:00
4.  CiscoWorks Common Services 3.3.0 27 Apr 2009, 11:14:32 GMT+03:00
5.  Device Fault Manager 3.2.0 27 Apr 2009, 11:14:33 GMT+03:00
6.  Health and Utilization Monitor 1.2.0 27 Apr 2009, 11:14:35 GMT+03:00
7.  Integration Utility 1.9.0 27 Apr 2009, 11:14:34 GMT+03:00
8.  Internetwork Performance Monitor 4.2.0 27 Apr 2009, 11:14:34 GMT+03:00
9.  LMS Portal 1.2.0 27 Apr 2009, 11:14:34 GMT+03:00
10.  Resource Manager Essentials 4.3.0 27 Apr 2009, 11:14:35 GMT+03:00
The sysObjectID of the devices in question are:
RFC1213-MIB::sysObjectID.0 = OID: CISCO-PRODUCTS-MIB::cat6509
RFC1213-MIB::sysObjectID.0 = OID: CISCO-PRODUCTS-MIB::cisco7609s
RFC1213-MIB::sysObjectID.0 = OID: CISCO-PRODUCTS-MIB::cisco7206VXR
RFC1213-MIB::sysObjectID.0 = OID: CISCO-PRODUCTS-MIB::catalyst37xxStack
Thanks a lot
Gautam
Community Member
Re: Question mark in Ciscoworks LMS 3.2 for common services
Dear Friends,
I am not sure if this question mark is coming because the device count appears as 0 when i go to:
Common Services-->Device Update
Product Name Device Type Count
1.Campus Manager0
2.CiscoWorks Common Services0
3.CiscoWorks Assistant0
4.Device Fault Manager0
5.Internetwork Performance Monitor0
6.LMS Portal0
7.Integration Utility0
8.Health and Utilization Monitor0
Thanks a lot
Gautam
Community Member
Just wanted to add the sysobjectID again in numerical format viz.
7609: .1.3.6.1.2.1.1.2.0 = OID: .1.3.6.1.4.1.9.1.864
6500: .1.3.6.1.2.1.1.2.0 = OID: .1.3.6.1.4.1.9.1.283
3750: .1.3.6.1.2.1.1.2.0 = OID: .1.3.6.1.4.1.9.1.516
7200: .1.3.6.1.2.1.1.2.0 = OID: .1.3.6.1.4.1.9.1.222
Thanks a lot
Gautam
811
