You want to use ISE to set up TACACS on Nokia 7750 SR, does it work?
The content you are looking for has been archived. View related content below.
For Cisco WS-C9200L-24T-4G-E, a user tried to backup configuration from Web portal. But did wrongly that uploaded empty text file to the device.That is:Copy to devicetftpaaa.txt (created from local computer)startup-configupload to device.Now the star...
I have a exanic x25 I wanted to know how and from where can we increase this size of the tx buffer. Any help or suggestio?
Hello,I upgraded our On-Prem server from Release 8-202201 to 8-202206. After the upgrade I'm not able to login to the GUI. We used TACACS+ (ISE) to authenticate. Also the local admin user is not working: "The requested user is not found".From the CLI...
Hello,i have a pc connected to VPC Peer Switch (vPC2) which has the secondary role. vPC2 builts a vPC with vPC1. How can i configure the port to always keep up the connection for this device, even when peer-link goes down (dragging out the cables).In...
I have upgraded cisco NCS-5504 router . Router was successfully upgraded but all the line cards are not showing. In platform command type is unknown and state is SW_Inactive.Regards Salman
Hello. We're currently running Meraki, and there is an issue we found. As far as I know, MX failover is automatically activated when the WAN is disconnected. If WAN Loss reaches a certain threshold, can't you force failover to Unit 2? Thank you.
This started about last week; no changes have been made to any of the switches. We're a small business so not very many employees, but we're a TV station so we have multitudes of servers.Our Primary ISP is a 2gig by 2gig connection, same as our Secon...
My network endpoints use the IP addressed vlans on my core cisco layer three core switch as their gateway addresses. i.e.- vlan 11 endpoint address 192.168.11.3/24 with gateway 192.168.11.1/24 (vlan ip on core) and vlan 12 endpoint address 192.168.12...
I have a couple of Cisco Firepowers that I can access thru SSH or the FDM, but I can't console to them?-Software version: 7.0.5-72-Configured with primary and secondary-Base license-Not using FMCCan someone tell me how to get console access? Thank yo...
how to get Original Equipment Manufacturers (OEMs)
I'm trying to have EEM script where I run the script manually and it display the output of the results in the session but for some reason I'm unable to do so. This is what I have so far(config)#event manager applet TestCommand(config-applet)# event n...
Hello all, I have inherited an infrastructure with several catalyst 9200 switches. A few of them are unreachable when using ssh from a terminal, such as a linux server or Powershell. The error message is this: Unable to negotiate with <IP ADDRESS> po...
I want to create an ACL on Cisco to prevent one network from communicating with others except for the internet. Can you help?
Having tried to register the MAC address on the website, the LED on the device is still flashing blue.
Subject | Author | Posted |
04-24-2024 04:03 AM | ||
04-23-2024 05:52 PM | ||
04-23-2024 12:20 AM | ||
04-16-2024 04:45 AM | ||
04-16-2024 01:33 AM |
User | Count |
3 | |
2 | |
2 | |
2 | |
1 |
