"Device Collection Failed" for PIX firewall device
Trying to do Ciscoworks Inventory Collection on a PIX firewall that is running old 4.2(5). I'm working with what I'm given. Oh well.
The task failed with the result message of "Device Collection Failed."
I took a look at IC_Server.log for results. I attached the pertinent output as file IC_Server--snapshot.log. According to the log messages, the collection failed due to "SnmpRequestTimeout".
The Ciscoworks server is able to ping and telnet to the PIX. I ensured Ciscoworks is using the correct SNMP string that is configured on the PIX. I initiated a snmpwalk from Device Center. The snmpwalk fails.
The following are the SNMP configuration on the PIX.
snmp-server host inside 10.76.144.199
snmp-server community xxxxxx
Firewalls that are running 6.x are recognized by Ciscoworks. Could it be that Ciscoworks does not like the 4.2(5) version?
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: "Device Collection Failed" for PIX firewall device
Your PIX must be running at least 6.1(1) code for LMS to support it.  This is documented at http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/device_support/table/lms32sdt.html .
1 REPLY
684
