Community Member
"switches reported as partially successful"
switches are reporting as "partially successful" due to the VLAN config fetching issue . I am attaching the screen shots for these errors.
Re: "switches reported as partially successful"
In order for RME to fetch the vlan.dat, it must be able to login to the switch via telnet or SSH, then copy the config back to the RME server using TFTP. Since you didn't post any errors, I have no idea exactly which part of this is failing, but make sure the username/password configure in DCR is correct for these switches, and make sure TFTP is allowed between device and server.
Community Member
I am getting these messages on my distribution switches. all are transparent mode.
RUNNING Apr 20 2009 14:31:00 Command failedTELNET: Failed to establish TELNET connection to 10.10.0.1 - Cause: Connection refused. VLAN Config fetch is not supported using TFTP. VLAN Config fetch is not supported using RCP.
Community Member
Create a vlan on the switch, this will make a vlan.dat in flash, too.
After that, CW will download this vlan.dat and your config job runs fine without partially collected.
Even if u delete the created vlan, the vlan.dat will keep in flash.
Does the vlan.dat file exist on these switches?
Community Member
No,we ar using the 6509 switches.
if we create a new vlan.dat and uploaded into the flash .it is not adding because zero bytes.
kindly advice me .
You are seeing CSCsq66458. As you already guessed, the workaround is to create a bogus vlan.dat file on flash. Since VTP transparent mode does not use vlan.dat, and you cannot use the workaround, you must ignore the partial failures until the fix comes out in RME 4.3 (part of LMS 3.2) this summer.
Community Member
Hi Clarke,
Thanks for the valuable information, but in our network one 3750 switch transparent mode is having vlan.dat file in flash and SVI,s.But this switch also showing "partilly successfully"
What errors are you seeing for this 3750?
Community Member
In the LMS, i am getting partially succefully.
What is the specific error? For the other switch it was:
Community Member
yes, same message
Then there must be a reachability issue with TFTP from the device to the server. Create an empty vlan.dat in the server's tftpboot directory. Make sure the permissions allow all users full control.
SSH to the problem device, and do:
copy flash:vlan.dat tftp://SERVER/vlan.dat
Where SERVER is the IP address of the server. What output do you get?
Community Member
Hi Clarke,
These are the steps we tried, the details are given below:-
Layer 3 Switch
RFHostel1#copy flash: tftp:
Source filename []? vlan.dat
Address or name of remote host []? 86.36.71.22
Destination filename [vlan.dat]?
%Error opening tftp://86.36.71.22/vlan.dat (Timed out)
Layer 2 Switch
ITS01S1#copy flash tftp:
TFTP: error code 2 received - 16739
%Error opening tftp://86.36.71.22/vlan.dat (Permission denied)
1) I checked the firewall, the tftp port is opened.
2) My management interface and server Ip address are different. ping reach ability is there.
kindly advice any other workaround to solve this issue.
The first error indicates that TFTP is being blocked. In order for TFTP to work, udp/69 AND all high UDP ports must be open between device and server.
The second error could indicate that you did not create the empty vlan.dat file on the TFTP server before doing the copy.
316
