Rate limiting of Cisco Catalyst 2950
I need to do the rate limiting of ethernet ports in a Cisco Catalyst 2950 switch such as 512kbps, 1 Mbps etc.
Is it possible to do the stuff in particular switch?
If yes, Can u pls provide the configuration steps.
1 REPLY
Bronze
Re: Rate limiting of Cisco Catalyst 2950
Yes it is possible to do the rate limiting of ethernet ports in a Cisco Catalyst 2950 switch. In terms of rate limiting, the Cisco Catalyst 2950 Series is capable of allocating bandwidth based on several criteria, including MAC source address, MAC destination address, IP source address, IP destination address, and TCP/UDP port number. The following URL will provide the configuration steps
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_6_ea2/configuration/guide/swgqos.html#wp1025277
1515
