Rate Limiting on cisco devices
Hi all,
I am using a small network equipped with cisco 2950 switches and cisco 2611 routers. Would like to know if there is possibility to limit the rate for a port or for an Ip address at let's say, 64kbps or 128kbps.
Thks in advance for your help.
Silver
Re: Rate Limiting on cisco devices
Hi ,
Answering to your question, Policing is the way to limit traffic to a certain BW, QoS Policing is supported on almost all Switching platforms (2950, 2960, 3550, 3560, 3750, 4500, 6500 and some other). To configure policing is not 1 single command, policing is a series of commands (you need to defina a class-map, assign the class-map to a
policy-map where you configure the limit values and then apply the policy map to the interface).Now keep in mind that when doing QoS on switches the commands vary depending on the platform.If you are looking for 1 command only, then some of the switches support the feature on he "Outbound" traffic to limit throughput but only for
output direction, it is explained below.
LIMIT INPUT TRAFFIC:
As mentioned in previous email, to limit the traffic coming into a port
you must configure policing, there is NO single command, QoS Policing
requires a series of commands:
1) Define a class-map
2) Define a policy-map (here you configure the BW limitation you need
for example the 256k
3) Apply the policy-map to the interface.
LIMIT OUTPUT TRAFFIC
If you want to limit the output throughput on a port you have 2 choices.
A) Configure Policing
B) Configure a single command: <<=====================================
This example shows how to limit the bandwidth on a standard port to 80
percent:
Switch(config)# interface gigabitethernet1/0/1 Switch(config-if)#
srr-queue bandwidth limit 80
When you configure this command to 80 percent, the port is idle 20
percent of the time. The line rate drops to 80 percent of the connected
speed, which is 800 Mbps (as this example is applied to a giga
interface).
http://www.cisco.com/en/US/products/hw/switches/ps5532/products_configuration_guide_chapter09186a008067edcc.html#wp1163881
This last command is only available for output traffic and is available for 2960, 2970, 3560 and 3750.There are no other options.
Hope it helps you
satish
This is a good orientation. But it looks like it is no possible to allocate a bandwidth less than 1Mbps for a port on 2950 switch.
Rgds
169
