Hi there
It seems that when deploying a private config file from a field device to a local hot-standby device using RCP as a deploument method, the configuration is deploying OK, but it is not saving. I was wondering if this was normal?
Steps we are taking
- opening a config from the shadow copy location in RME Config Editor
- save it as a private file
- Deploy config to a standby router (using RCP)
- Tick the box "Copy running to startup"
The goal here is to be able to do everything through the web interface at a Help Desk or 1st / 2nd level network technician level. The stanby router is on the local network with a static and simple configuration.
I'm guessing that the config is copying across OK, but for some reason not saving to startup config, possibly due to the IP address change?
