Community Member
Re-installing LMS 2.6 lead to an ANIServer connection issue
I re-installed LMS 2.6 on a Windows Server for a customer, restored the previous backup and encountered the following problem when dealing with Campus (Topology) : "Cannot connect to ANI Server".
When I restore a backup on a new installation. Do the new ANI database password has to be the same as the previous one (the one in the backup) ?? Because I think the new password is different... and wondering if it could be the root cause.
Thanks for your Help !
Blue
Re: Re-installing LMS 2.6 lead to an ANIServer connection issue
Is the new server using the same hostname (DNS name) as the old one?
Find the "ANIServer.properties" file and verify the line reflects the new server's hostname:
AniName=ANIServer6.0-hostname
Community Member
Yes, the new server is using the same Hostname.
Is the ANIdb password important ? because I've a line in the CampusOGSServer.log log file saying DB connection refused :
java.lang.Exception: Error occurred in evaluating the sql Query java.sql.SQLException: Could not establish DB connectivity java.sql.SQLException: JZ006: Caught IOException: java.net.ConnectException: Connection refused: connect
Thanks for your help
Cedric.
Yes, this could be an issue; shut down daemon manager. For this, issue the following command in a DOS box:
net stop crmdmgtd
then run this script to set the database passwords for all databases:
NMSROOT\bin\perl.exe NMSROOT\bin\dbpasswd.pl all
restart the daemon manager with
net start crmdmgtd
142
