01-28-2007 03:42 AM
I install CM. by campus manager I can see the view my network. But can i get instally chage see in CM network view.
like an example when router or link is down then time it shows automatically that your device down .
or when it periodically discover then time I found out that it up or down ?? ???
Biplob
01-28-2007 10:05 AM
It won't be instant, the topology map will be updated when CM completes its next polling cycle.
01-31-2007 11:54 PM
You may like to change the default polling setting to shorter time frame (may be 5mins) That will generate a lot of traffic and not recommended practise.
And who would like to be in front of monitor 24/7??
You have sms/email to inform you when link/device is down!!
I hope you get what real network management means. :)
Cheers!
