Recommendation Needed for ACL Manager Replacement
All,
Since ACL Manager is end-of-life, does anyone have a recommendation for a replacement tool?
Stephanie
1 ACCEPTED SOLUTION
Re: Recommendation Needed for ACL Manager Replacement
Some of the features of ACL Manager were rolled into the Cisco Security Management Suite. You might want to check that bundle out:
http://www.cisco.com/en/US/products/ps6498/index.html
Our device ACL has 17,000+ lines.
Is there a non-cisco tool which can manage large ACL's?
190
