Reinstallation issue
I did a reinstalltion and restore of a BU for a LMS 2.5 and now i see that i have choosen another directory to install te LMS 2.5, different then before
(it was was something like \CW2K\CSCOpx and now \CSCOpx), can this give any problem after the restore or do i need to change some parameter, the reason is that i ask this question i have problems with the CM > can't connect to ANIServer > unknown error.
Thanks to help
1 REPLY
Re: Reinstallation issue
LMS 2.5 and higher allows for restoring into different directories. However, if the hostname or IP addresses has changed, then you will have to follow the procedure in the LMS documentation to update those values. That could cause the error you are seeing, but so could other things. The ANIServer.log and ani.log may provide you more clues.
93
