Community Member
Remote vlan assignment
I have a requirement whereby an end station belongs to one vlan, however, a customized management station must have the ability to switch the vlan assignment. My problem is that the management station does not know the port associated with the end station. I was thinking of using some type of eem script/applet to send a trap to the management station with the ip/port/vlan associated with the end station - since it now knows the port associated with the ip it could then change to the appropriate vlan when necessary via snmp. Would this even be possible?
197
