05-19-2006 01:45 PM
How can unconnected devices be removed from Campus 3.3 using a sql select statement in the dbreader?
05-21-2006 02:35 PM
I haven't looked at the database tables yet, please keep in mind the following:
- the database is loaded into memory, so in order for the sql statement to take effect, you will have to stop / start JRunProxyServer and ANIServer
- when you stop / start ANIServer, a new discovery will start which will probably result in the devices popping up in Unconnected Devices View
- your best bet would be to set up discovery filters so the devices in Unconnected Devices View don't get discovered
- once that is done, you may go to Unconnected Devices View and delete all the devices that are in there via the GUI. They shouldn't come back.
05-21-2006 09:50 PM
I wonder why you wish to do this.
The unconnected devices are in a seperate group already. Why delete them as they probably will be rediscovered.
Cheers,
Michel
