Reporting on GBICs in LMS 2.6
In RME 3.5, I'm able to run RME> Administration> Custom Reports> select the View, then select Custom Card reports and 'am able to report on and see serial numbers for GBICs on 3550-24s, 3550-48s, 4506s and 4006 switches.
How can I create the same report in LMS 2.6 using a Custom Report Template to report the same information?
Here is the Custom Card Report output from RME 3.5 showing just the GBICs, their serial numbers and such. You may need to copy and paste the output below into notepad or something to view it a little better.
Device Name Card Index Card Type Serial Number SW Version HW Version
lohlakc2.oh.kp.org 1003 cevMGBIC1000BaseSX A53066037 null 0
lohlakc2.oh.kp.org 4007 cevMGBIC1000BaseSX AGS084008GG null 0
lohlakc2.oh.kp.org 4009 cevMGBIC1000BaseSX AGS084008U5 null 0
lohlakc2.oh.kp.org 4011 cevMGBIC1000BaseSX FNS0916E4M8 null A
lohlakc2.oh.kp.org 4008 cevMGBIC1000BaseSX AGS084008H4 null 0
lohlakc2.oh.kp.org 4010 cevMGBIC1000BaseSX FNS0916E4JQ null A
lohlakc2.oh.kp.org 4012 cevMGBIC1000BaseSX FNS0916E4JH null A
lohlakc2.oh.kp.org 5007 cevMGBIC1000BaseSX AGS084008FQ null 0
lcaalac30.ala.ca.kp.org 28 cevMGBIC1000BaseSX AGS10140373 null 30 30 30 30
lcaalac30.ala.ca.kp.org 29 cevMGBIC1000BaseSX AGS1014036M null 30 30 30 30
lcaamdc1.ca.kp.org 2007 cevMGBIC1000BaseSX AGS09200F9B null 0
lcaamdc1.ca.kp.org 2008 cevMGBIC1000BaseSX AGS09200FAG null 0
lcaamdc1.ca.kp.org 2009 cevMGBIC1000BaseSX AGS09200F99 null 0
lcaamdc1.ca.kp.org 2010 cevMGBIC1000BaseSX AGS09200F9R null 0
lcaamdc1.ca.kp.org 2011 cevMGBIC1000BaseSX AGS09200B6Z null 0
lcaamdc1.ca.kp.org 2012 cevMGBIC1000BaseSX AGS09200FBE null 0
lcaamdc1.ca.kp.org 3007 cevMGBIC1000BaseSX AGS09200FBB null 0
lcaamdc1.ca.kp.org 3008 cevMGBIC1000BaseSX AGS09200FB7 null 0
lcaamdc1.ca.kp.org 3009 cevMGBIC1000BaseSX AGS09200F9E null 0
lcaamdc1.ca.kp.org 3010 cevMGBIC1000BaseSX AGS09200FB9 null 0
lcaamdc1.ca.kp.org 3011 cevMGBIC1000BaseSX AGS09200B5Z null 0
lcaamdc1.ca.kp.org 3012 cevMGBIC1000BaseSX AGS09200FA1 null 0
lcahayc100.hay.ca.kp.org 52 cevMGBIC1000BaseLX A10193465 null 30 30 30 30
lcahayc100.hay.ca.kp.org 53 cevMGBIC1000BaseSX F42063942D88 null 20 20 20 20
lcasscc114.ssc.ca.kp.org 21 cevMGBIC1000BaseT FHH0815T02J null 20 20 20 20
lcasscc114.ssc.ca.kp.org 20 cevMGBIC1000BaseT FHH0815T2GM null 20 20 20 20
lcasscc114.ssc.ca.kp.org 14 cevMGBIC1000BaseSX F413639452CF null 20 20 20 20
lcasscc114.ssc.ca.kp.org 15 cevMGBIC1000BaseSX F413639451D0 null 20 20 20 20
lcasscc114.ssc.ca.kp.org 16 cevMGBIC1000BaseSX F413639451D3 null 20 20 20 20
lcasscc114.ssc.ca.kp.org 17 cevMGBIC1000BaseSX 96EYS108PW2 null 30 31 20 20
lcasscc114.ssc.ca.kp.org 18 cevMGBIC1000BaseSX 96EYS108K6B null 30 31 20 20
lcasscc114.ssc.ca.kp.org 19 cevMGBIC1000BaseSX 96EYS108NWY null 30 31 20 20
lcahrbc129.ca.kp.org 52 cevMGBIC1000BaseSX B33863941187 null 20 20 20 20
lcahrbc129.ca.kp.org 53 cevMGBIC1000BaseSX B338639417BE null 20 20 20 20
1 ACCEPTED SOLUTION
Re: Reporting on GBICs in LMS 2.6
Currently scheduled for late Spring of this year.
I picked one of each of the following models of devices: 3550-24s, 3550-48s, 4506s and 4006 and generated a detailed device report for each using LMS 2.6.
None of them report serial numbers for any GBIC connectors. The 4006 and the 4506 did report on the GBIC modules but did not report on the GBIC connecter connected to that module.
In RME 3.5, I was able to run a Custom Card report and not see the GBIC modules on the 4006 and 4506 devices but was also able to see the GBICs AND their serial numbers. Also, I was able in the Custom Card reports in 3.5 to see the GBIC connector on the remaining models and see the connectors and the serial numbers to the connectors.
This is not going to be an acceptable solution for the customer.
I certainly hope this will be corrected in LMS 3.0. I think it's a very big problem that we've lost this functionality going to the new release.
Unfortunately, this is not possible in RME 4.0. There is a bug, CSCsh37900, which is currently slated to be fixed in LMS 3.0 which will re-add this capability.
Do you know when 3.0 will be released?
172
