Required components of CiscoWorks for inventory
Plutakhin
Hello! What components of CW should I use for config and software management and for inventory? For example can I use CW without DFM and Campus manager for this purposes? Should it be cheaper, then whole CW?
5 Replies 5
Joe Clarke
The Resource Manager Essentials application does both config and software management. You cannot purchase individual LMS components. You must buy the whole bundle.
And the same about support?
What about support?
Can I choose support only for one of components of CW.
No. When you purchase CiscoWorks LAN Management Solution, you have to purchase a support contract on the entire bundle (or no contract at all).
