Community Member
Reserving bandwidth using QOS
I am using below config to reserve bandwidth. will the config work.
class-map match-all AB
match access-group name C
policy-map Test
class AB
bandwidth 500
interface Port-channel1
ip address x.x.x.x x.x.x.x
ip ospf network point-to-point
service-policy output Test
1 REPLY
Bronze
Re: Reserving bandwidth using QOS
Don't forget to use "max-reserved-bandwidth 100" on the interface with the policy. If you don't you are limited to having 75% of the BW of the interface "reservable" since IOS "keeps" 25% for overhead. If you know what your traffic is, use the above so you can control 100%.
Note: in our QoS policies we always have a class for telnet/ssh/ftp/syslog/ntp/etc. so we can reach the device even when it's busy...
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_white_paper0900aecd803e5017.html
112
