07-25-2007 05:51 AM
I needed to reset my 2611 router and reload the config to troubleshoot something - I seem to remember a procedure I needed to do to generate a local certificate or something in order to enable ssh - can someone point me in the right direction? nothing else in the config related to ssh has changed.
07-25-2007 11:50 AM
Try the two commands in the following order from the global config mode.
crypto key zeroize rsa
crypto key generate rsa
Sundar
07-25-2007 01:20 PM
Thanks, crypto key generate rsa is what did it.
