Resource Manager Essentials 3.5 Inventory Problem
I have problem with my CW2000.
Sometimes when I select "List Devices" from RME->Admin->Inventory it shows no entries found. This is also the same when I try to use any RME function that requires me to select devices. But when I look in RME->Admin->Inventory->Import Status it shows 603 Managed devices which is correct.
Any idea what could cause this problem
1 ACCEPTED SOLUTION
Red
Re: Resource Manager Essentials 3.5 Inventory Problem
You may be running into CSCef50925:
RME Inventory Display problems
If you are on Solaris, try these commands:
/opt/CSCOpx/bin/pdterm DIServer ICServer
/opt/CSCOpx/bin/pdexec DIServer ICServer
If you are on Windows, open a DOS shell and go to CSCOpx\bin. Issue the commands (case sensitive):
1 REPLY
Red
102
