Community Member
Restore LMS backup from 32 bit to 64 bit OS
Hi, we are moving from a Windows 2003 32 bit server to 64 bit installation. Does anyone know if I can restore the 32 bit LMS backup to the newly installed 64 bit without causing myself any problems?
Thank you in advance.
1 REPLY
Re: Restore LMS backup from 32 bit to 64 bit OS
Yes, this is possible. You cannot, however, restore from Windows to Solaris or vice versa.
125
