04-05-2006 06:18 PM
I am try to set up a reverse telnet seesion between AUX port of 3725 Router to the console port of a master switch in a 3750 Stack configuration. The configuration on the AUX port is as follows:
line aux 0
exec-timeout 20 0
no exec
transport preferred none
transport input all
transport output all
stopbits 1
And on the Switch side, the configuration is as follows:
line con 0
exec-timeout 60 0
password 7 XXXXXXXXXXXXX
I enter en the foolowing command from the router and I get the following:
telnet X.X.X.X 2097
Trying X.X.X.X, 2097 ...
% Connection refused by remote host
Deleting login session
I have tried using a rollover cable and a straight through cable between the devices but the result is the same. Does anyone have any ideas on how to make this work?
04-05-2006 07:23 PM
Can you enter the following on the aux port:
line aux 0
exec
Paresh
04-05-2006 07:51 PM
I tried that but the results are still the same. Do I have to add anymore detail to "console 0"
