Community Member
RFC1213-MIB:System "OID not supported by device"
"OID not supported by device". This is the message received when Solarwinds Cirrus v4 attempts to read the RFC1213-MIB:System MIB>. Device is c3750e running IOS 12.2(44)SE1. Using SNMPv3 authpriv security level. Any idea why certain MIB-2 MIB's are unavailable?
Re: RFC1213-MIB:System "OID not supported by device"
Please post the SNMP configuration of this device as well as the exact OID you are trying to query. The RFC1213-MIB::system OID is a branch and not a leaf. Therefore, it cannot be queried directly. You would have to do a GET-NEXT query on it.
Community Member
snmp-server group CirrusGroup v3 priv context SNMPv3
snmp-server context SNMPv3
gdcswhnwh047#sh snmp group
groupname: CirrusGroup security model:v3 priv
readview : v1default writeview:
notifyview:
row status: active
gdcswhnwh047#sh snmp user
User name: CirrusUser
Engine ID: 800000090300001FCA982481
storage-type: nonvolatile active
Authentication Protocol: SHA
Privacy Protocol: AES128
Group-name: CirrusGroup
gdcswhnwh047#sh snmp view
v1default iso - included permanent active
v1default internet - included permanent active
v1default snmpUsmMIB - excluded permanent active
v1default snmpVacmMIB - excluded permanent active
v1default snmpCommunityMIB - excluded permanent active
v1default ciscoMgmt.252 - excluded permanent active
The Solarwinds Cirrus v4 Configuration Management tool is attempting to capture System Info from the RFC1213-MIB::system branch. I assume that it is actually doing a get-next or get-bulk. But, using a MIB browser I could not view any leaves from the System branch on the Cisco 3750e.
Hope that helps.
Pete W.
It may be that SolarWinds doesn't support SNMPv3 authPriv with AES128 crypto. A sniffer trace of the SolarWinds-to-device traffic would be very helpful.
Community Member
jclarke,
Thanks for the help. I finally found some good information on the Solarwinds User forum. In case anyone else is having issues with Solarwinds Cirrus and SNMPv3 I have included the IOS commands:
snmp-server group Cirrus v3 priv
snmp-server view CirrusView internet included
snmp-server view CirrusView system included
snmp-server view CirrusView interfaces included
snmp-server view CirrusView chassis included
snmp-server user CirrusUser Cirrus v3 auth sha MyAuthPass priv aes 128 MyPrivPass
Thanks again,
Pete W.
936
