Community Member
RFC1213 no longer supported in 122-54.SG ?
After upgrading cisco 4510R-E from ipbasek9-mz.122-53.SG2 to ipbasek9-mz.122-54.SG we get no ouput when polling the routing table via snmp.
output 12.2(54)SG
snmpwalk -v1 -c public hostA ipRoute
(-> empty)
output 12.2(53)
snmpwalk -v1 -c public c4k-ww10-tk-1 ipRoute
RFC1213-MIB::ipRouteDest.0.0.0.0 = IpAddress: 0.0.0.0
1 REPLY
Community Member
Re: RFC1213 no longer supported in 122-54.SG ?
After searching the cisco.com site for 'ip route' Mib could not find the same in 'Snmp Object Navigator'
Here is the link with the results:
http://tools.cisco.com/Support/SNMP/do/SearchOID.do?objectName=ipRoute&searchMode=exactmatch&search=Search&submitValue=SUBMIT&jumpToPage=1&step=1
we have 'ip route table' which can be tried.
1. ipRouteAge
"The number of seconds since this route was last updated or otherwise determined to be correct. Note that no semantics of `too old' can be implied ...
2. ipRouteDest
"The destination IP address of this route. An entry with a value of 0.0.0.0 is considered a default route. Multiple routes to a single ...
3. ipRouteEntry
A route to a particular destination....
4. ipRouteIfIndex
"The index value which uniquely identifies the local interface through which the next hop of this route should be reached. The interface identified ...
5. ipRouteInfo
"A reference to MIB definitions specific to the particular routing protocol which is responsible for this route, as determined by the value ...
6. ipRouteMask
"Indicate the mask to be logical-ANDed with the destination address before being compared to the value in the ipRouteDest field. For those systems ...
7. ipRouteMetric1
"The primary routing metric for this route. The semantics of this metric are determined by the routing-protocol specified in the route's ...
8. ipRouteMetric2
"An alternate routing metric for this route. The semantics of this metric are determined by the routing-protocol specified in the route's ...
9. ipRouteMetric3
10. ipRouteMetric4
11. ipRouteMetric5
12. ipRouteNextHop
"The IP address of the next hop of this route. (In the case of a route bound to an interface which is realized via a broadcast media, the value ...
13. ipRouteProto
"The routing mechanism via which this route was learned. Inclusion of values for gateway routing protocols is not intended to imply that hosts ...
14. ipRouteTable
This entity's IP Routing table....
15. ipRouteType
"The type of route. Note that the values direct(3) and indirect(4) refer to the notion of direct and indirect routing in the IP ar...
Podhillo
188
