Community Member
RICS0001 on 3560G inventory with LMS 3.2
I'm getting the following error while doing an adhoc inventory of a C3560G switch... I have plenty of those, but this one errors out for some reason.
I've attached the relevant section of IC_Server.log, hope somebody can figure out what is wrong.
Running LMS 3.2 on Windows 2003. The switch is a Catalyst 3560G running IP Service version 12.2(52)SE.
Thanks!
Alex.
1 ACCEPTED SOLUTION
Re: RICS0001 on 3560G inventory with LMS 3.2
This is known bug CSCta05277.  It will be fixed in LMS 4.0.  In the meantime, deleting the device from RME, then re-adding it will correct the problem, but the problem could return.
1 REPLY
254
