05-18-2009 06:37 AM
I was wondering if someone please advise on what Java version I need to run Cisco works 6.0 nad later without error? as is i canot run the campus manager at all given the unsupported java version on my pc. I am acessing this application via brower - IE7.
I remember something from a few years ago, Java version 6.4.1.xx if I am not mistaken!?
Masood
Solved! Go to Solution.
05-18-2009 07:12 AM
Yes, 1.4.2_15 is the only version of Java that will work with this version of Campus. You will need to have your administrator uninstall other JVMs on your client, and install the 1.4.2_15 from the CiscoWorks server.
05-18-2009 06:40 AM
There is no CiscoWorks 6.0. What version of Campus Manager do you have?
05-18-2009 06:49 AM
Thanks for your prompt response. Well I tried to run it and it is asking for java version: SE V1.4.2_15 but installation fails because I don't have admin rights on my PC?
License Info:
UPGRADE Copy
Version & Patch Level: 4.0.9
Installation Date:
Fri Jul 01 16:52:51 EDT 2005
LMS2.6 01 Jul 2005
Masood
05-18-2009 07:12 AM
05-18-2009 10:36 AM
Ho wabout the IE? it also tells me that I am using unsupported IE?
We are using IE7!?
I also get certificate error? -usually certificate errors don't prevent the application from working except that it is kind of annoying!
Please advise.
Masood
05-18-2009 10:58 AM
IE 7.0 support was not added until LMS 3.0. LMS 2.6 only supported IE 6.0 and Mozilla 1.7.
The certificate error occurs because you are using a self-signed certificate. You can either import the certificate into your browser, or purchase a CA signed certificate, and install it into LMS.
