05-14-2007 05:06 PM
My guess is RME 3.5 is no longer being sold thus EOS.
When will RME 3.5 stop being supported...correct me if I'm wrong but I would guess this is EOL.
One more question: in what document can I find the max number of supported devices for RME?
Thanks in advance. Rob
Solved! Go to Solution.
05-14-2007 05:15 PM
This is documented in the RME 3.5 release notes. The number is 5000 provided RME is installed on a server by itself.
05-14-2007 05:08 PM
LMS 2.2 is EOL and EOS. It will be EOSupport on July 31, 2008. See http://www.cisco.com/en/US/products/sw/cscowork/ps2425/prod_eol_notice0900aecd802136a2.html for all the dates.
05-14-2007 05:09 PM
Thanks for the quick response. As you can see, I added one more question...it's for RME 3.5.
05-14-2007 05:15 PM
