04-26-2006 06:24 AM
I've got a whole building full of Cat6k's with SUP32 that LMS 2.2 (RME 3.5 IDU 13) refuses to upgrade. Does anyone know what this error means? This is generated by RME -> Software Management -> Distribution -> Distribution by Devices.
Slot 8.
Model : WS-SUP32-GE-3B
Type : 50x
HW Version : 4.x
FW Version : 12.x
SW Version : 8.x(x)
Skip Reason : Redundant supervisor module has same image as the Active
supervisor module. The upgrade of the Active supervisor
module will also upgrade this module.
04-26-2006 06:29 AM
It looks like RME thinks you are trying to upgrade the standby supervisor module.
If RME hasn't correctly picked up which one is Active, perhaps an Update Inventory followed by Software Distribution would fix this.
04-26-2006 06:29 AM
Thanks for the speedy response. I'll give it a try.
04-26-2006 08:11 AM
Well, updaing inventory didn't help. Then I tried deleting (suspending) the devices and resubmitting them, to no avail either. So I bit the bullet, deleted all of the "problem children" and re-added them back. After clicking "submit" in RME -> Software Management -> Distribution -> Distribution by Devices, I get:
Slot: 7. Model: WS-SUP32-GE-3B Cause: Not Applicable
Slot: 8. Model: WS-SUP32-GE-3B Cause: Redundant supervisor module has same image as the Active supervisor module. The upgrade of the Active supervisor module will also upgrade this module.
Slot: 15. Model: WS-F6K-MSFC2A Cause: Not Applicable
Slot: 16. Model: WS-F6K-MSFC2A Cause: Redundant supervisor module has same image as the Active supervisor module. The upgrade of the Active supervisor module will also upgrade this module.
Ok.
But when I click "Details" on that page:
Device Name router65133b1.domain.com
Chassis Type WS-C6513
Number Of Slots 13
Description 13 slot Switch
Slot 1.
Model : WS-X6148A-GE-TX
Type : wsx6148agetx
HW Version : 1.0
FW Version : 8.x(x)
SW Version : 8.x(xa)
Skip Reason : Not Applicable
Slot 2.
Type : wsx6148agetx
HW Version : 1.0
FW Version : 8.x(x)
Slot 3.
Type : wsx6148agetx
HW Version : 1.0
FW Version : 8.x(x)
Slot 4.
Type : wsx6148agetx
HW Version : 1.0
FW Version : 8.x(x)
Slot 5.
Type : wsx6148agetx
HW Version : 1.0
FW Version : 8.x(x)
Slot 6.
Skip Reason : Empty
Slot 7.
Type : 509
HW Version : 4.1
FW Version : 12.x(x)
Slot 8.
Type : 509
HW Version : 4.1
Slot 9.
Skip Reason : Empty
Slot 10.
Skip Reason : Empty
Slot 11.
Skip Reason : Empty
Slot 12.
Skip Reason : Empty
Slot 13.
Skip Reason : Empty
What to do now?
04-26-2006 08:22 AM
So the active sup is in slot 7, correct?
What is the file name of the CatOS that you are trying to distribute?
04-26-2006 09:53 AM
The file name is cat6000-sup32pfc3k9.8-4-4.bin. Does it have something to do with RME not supporting SUP32 fully? I just find out in Inventory -> Custom Report, SUP32 is known as Card Type 509 (there's another unknown Card Type: 599). None of our SUP32 cat6k switches are found as upgradable by the above image.
04-26-2006 10:17 AM
It could very well be. The sup32 is not recognized in RME 3.5, IDU 13.0
Rumor has it that there will be an IDU 14.0 for RME 3.5 that will contain support for the sup32
Not clear when the release would be
