RME 4.0.4 Configlets not showing Vlans
Our customer is running RME 4.0.4.
When looking in Config Viewer under Raw data the whole config is seen. When using the Processed option all folders show their part of the config except Vlans.
Click on folder Vlan and you get the sub folder Vlan 10,20,30,40 but no data in the 3rd pane.
Customer is saying this happens for following devices only.
3560 24 PS Switch
2950T 48 SI Switch
2950 12 Switch
I have checked the forum and also bug tool with no success. Any suggestions welcome?
Alan
1 REPLY
Silver
Re: RME 4.0.4 Configlets not showing Vlans
If you modify the Security Contexts policy for a system context of an FWSM and reference a VLAN that does not exist in the Interfaces policy for the same system context, the VLAN is created on the FWSM when you next deploy to the system context.
113
