RME 4.0.5 / web page don't appear
Hello
I have a LMS 2.6 installation with RME 4.0.5.
All works fine except that after 1-2 weeks without problems, the web page http://ciscoworks:1741/rme/RMEHome.do
don't appear (page timeout).
All the RME services are running
CS, DFM, CM pages appears correctly
As workaround I execute a restart of CW.
Do you known this problem?
best regards
Andrea
Re: RME 4.0.5 / web page don't appear
We have seen reports that the RME homepage no longer shows up when there are a large number of RME jobs. Removing old jobs via the RME Jobs manager helps that problem. There may also be errors in the NMSROOT/MDC/tomcat/logs/stdout.log that point to a cause for this problem.
Hello
My last RME Job is 1133 (total saved jobs are 231).
It's seems that the RME stop to work because my last job was at 21 jun.
I have max 1-2 job pro day.
Now I have restarted CW because I was not able to entry into the RME menu to erase Jobs.
Now I have erased 60jobs
You will find as attached file the stdout.log file
Best regards
Andrea
So with the deleted jobs, does the problem still occur?
Hello
before to delete the jobs I have restarted CW.
(..it's the workaround)
The problem appear every 1-2 weeks.
So I have to wait...
Did you see something wrong into the log?
Best Regards
Andrea
I didn't know at what time to look, but a scan of the log did not reveal anything obviously wrong.
Hello
the problem appears again, but this time I see the RME Homepage (CW it need 1 minute to display the Homepage, normally 2-3 sec).
But into the RME Homepage the RME Job are EMPTY.
The RME job browser page is EMPTY too.
Could I do some troobleshooting, without restart the LMS?
bye
Andrea
140
