RME 4.1.1 config archive problmes with ASA-5520
tim.davies
Hi there
I'm using LMS 3.0.1 and RME 4.1.1 to archive the configs of several ASA5520's. RME collection status reports that the Start-up and Running configs as "out of sync" on all the ASA5520's (other devices are fine). I have checked that the running and startup configs are in sync on the ASA devices and they are.
On investigation it seems that RME isn't collecting all the config from the ASA5520 devices. There are random parts of the config missing. I have tried collecting using telnet and SSH with the same problmes. I have also tried removing the devices from RME and adding them back in with no luck. Anyone any ideas?
ASA5520's are running 8.0(3)
Kind Regards
Tim
Joe Clarke
This is most likely my bug CSCsm71678. the bug is fixed in LMS 3.1, and a patch is available from the TAC for RME 4.1.1. If your engineer cannot find it, they can contact me directly to get it.
Joe Clarke
