Webcast-Catalyst9k
RME 4.2 config issue with 6509 / LMS 3.1
Yesterday after a crash, I restored with restorebackup.pl but then my 6500 config mgmt is not working. i.e. it
is not taking configs of the same. it provides an error as ....
1. PRIMARY RUNNING Aug 11 2009 15:57:55 CM0056 Config fetch failed for RIMS-1 Cause: CM0204 Could not create
DeviceContext for 1758 Cause: CM0206 Could not get the config transport implementation for 10.4.22.254 Cause:
CM0202 Could not access 10.4.22.254 via SNMP. Action: Check the Read Community string Action: Check if required
device packages are available in RME. Action: Check if protocol is supported by device and required device
package is installed.
i even checked all the credentials. all are fine. I checked the ACS but i could not find any administration
record for that. All the device updates are there.
i recently patched for the bug CSCsx58694.
pl help.
1 REPLY
Re: RME 4.2 config issue with 6509 / LMS 3.1
This points to a package problem within RME. What is the sysObjectID of this switch? Post the list of contents of NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/lib/pkgs and NMSROOT/www/classpath/com/cisco/nm/xms/psu/pkgs/rme.
130
