02-18-2009 12:42 PM
I have an ASA that fails SSH v1 or v2 in Management Station to Device tests, immediately. Yet, I can manually SSH (v2) on the server's CLI to the ASA just fine. It's not a timeout value issue. Is Management Station to Device test doing anything funky?
Solved! Go to Solution.
02-18-2009 01:27 PM
It is a timeout value issue. This is my bug CSCsx08790. The problem is the timeouts in the GUI are being evaluated as milliseconds instead of seconds. I wrote a patch (available from TAC), but the workaround is just to multiple your seconds by 1000.
02-18-2009 01:27 PM
