12-06-2011 01:53 AM
I try to change UserPort settings with Compliance Management :
Name:
CheckPort
SubMode: Yes
isPrerequisite: Yes
Ordered : No
Prerequisite-Commandset : none
Parent: none
interface [#.*#]
[#description user_10#]
Name:
Port
SubMode: No
isPrerequisite: No
Ordered : No
Prerequisite-Commandset : CheckPort
Parent: CheckPort
+ description test_rme
But it's not working.
Any hint for me ?
regards
Michael
Solved! Go to Solution.
12-07-2011 06:32 AM
I just tested this template on my server and I had no problems. The device originally had:
interface FastEthernet0/1
description user_10
no ip address
Ran compliance check and device was non-compliant as these commands needed to be deployed:
+interface FastEthernet0/1 |
+ description test_rme |
Ran deploy of this compliance job and now my device has:
no ip address
Now I do not have RME 4.3.0 to test so there might be a problem in the version. What does the compliance job say as a result, is it correct? If so, what happens when you deploy the job? These jobs run against the latest archived configuration in RME, so make sure the current running configuration is stored in RME or you might be getting unexpected results. You can check latest config under RME > Config Mgmt > Archive Mgmt > Version Tree.
My template:
12-06-2011 10:11 AM
What is it you are trying to do, change to "description test_rme" if an interface currently has "description user_10"? If so, you are missing:
+ [#description user_10#]
12-07-2011 01:48 AM
yes I want to change the description of each Port.
If the description is "user_10" it has to be changed to "test_rme"
I use this Template, but nothing happens :
SubMode: Yes
isPrerequisite: Yes
Ordered : No
Parent: none
interface [#.*#]
Name:
Port
SubMode: No
isPrerequisite: No
Ordered : No
Parent: CheckPort
regards
Michael
12-07-2011 06:32 AM
description user_10
no ip address
no ip address
My template:
12-08-2011 03:08 AM
working. Thanks.
That was the reason. We had trouble fetching actual configuration.
regards
Michael
