RME Alias Devices
I did a complete fresh install of Ciscoworks 2000, LMS2.5 and installed all the latest patches. After adding devices to CS, now there are 170+ ALIAS devices in RME. If you select the RME device and show alias devices, there is only one device--the same thing as the RME device. If you click the alias device and select, it says all other devices will be deleted and then I click ok. The device still shows up as being aliased and the same device in the alias box. How can I get this resolved?
113
