Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
RME Aliases
We are currently running RME4.3.1.  The Device Management State Summary shows that there are 41 Aliases.
Viewing the Alias Devices shows 8 devices. Clicking on the "Show Alias Devices" button for any of the 8 devices only shows the original device without listing any aliases. Using the "Select" button does not clear the alias.  Is there a solution to this?
1 ACCEPTED SOLUTION
Re: RME Aliases
There is, but you will need to contact TAC as it will involve some tactical cleaning of the RME database.
1 REPLY
Re: RME Aliases
132
