Webcast-Catalyst9k
RME Baseline Question
I would like to create a baseline template that checks for the presence of tacacs-server 10.1.82.24 and tacacs-server 10.2.82.25 and removes any other tacacs-server ip address that might be configured. Can someone help me create a template that would do this?
1 ACCEPTED SOLUTION
Re: RME Baseline Question
The following advanced rules evaluated in global mode should do it for you. This assumes you're using LMS 2.6 or higher.
+ tacacs-server 10.1.82.24
+ tacacs-server 10.2.82.25
- tacacs-server [#!(10\.1\.82\.24|10\.2\.82\.25)#]
Thanks Joe, worked perfectly.
How would you write the rule for:
tacacs-server host 10.24.195.204 key 7 *****
would it be:
"+tacacs-server host 10.24.195.204 *" ?
thanks joe.
I would include one crypto pattern, and make it a literal search:
+ tacacs-server host 10.24.195.205 key 7 abcdef
But you could do:
+ [#tacacs-server host 10.24.195.205 .*#]
would:
+ tacacs-server host 10.24.195.204 key 7 [#.*#]
+ tacacs-server host 10.25.144.46 key 7 [#.*#]
- tacacs-server host [#!(10\.24\.195\.204|10\.25\.144\.46)#] key 7 [#.*#]
work?
Yes.
144
