Webcast-Catalyst9k
RME Baseline template specific interface range
Does someone know how to specify a specific interface range in the "Submode" entry, for eg. interface range FastEthernet 0/1 - 20.
When interface [#Fast.*#] is specified all fa interfaces are selected, and this is not what I want.
Can anyone please help; :-)
Re: RME Baseline template specific interface range
Use a stricter regular expression. For example:
int [#FastEthernet0/[1-9]|11|12|13|14|15|16|17|18|19|20$#]
This:
interface [#FastEthernet0/[1-9]|10|11|12|13|14|15|16|17|18|19|20|21|22|23|24|25|26|26|27|28|29|30|40$#]
Works perfectly, however how can I specify the rest of the ports, this:
interface [#FastEthernet0/41|42|43|44|45|46|47|48$#]
Does not work, could you please help me again....thanks again, and again ... and again...:-))
Try:
int [#FastEthernet0/4[1-8]#]
Try:
int [#FastEthernet0/4[1-8]$#]
This could be simplified to:
int [#FastEthernet0/[1-9]|1[0-9]|20$#]
This thing is a real headache generator, unfortunately does this: "interface [#FastEthernet0/[1-9]|1[0-9]|20$#]" statement only produces the first 9 interfaces to be checked, so fa01 - fa0/9 ,and leaves the rest unbothered.
It seems that the | sign doesn't do the trick.
Any suggestions?
Try parentheses:
interface [#FastEthernet0/([1-9]|1[0-9]|20)$#]
Finally!!! It works.. youre THE absolute best!
Thanks again.
160
