Hi:
I have a large number of 3750 stacks consisting of a variable amount , from 1 to 6, switches. I need to add to all
FastEthernet interfaces from 2/0/1 to n/0/24 a command , under the interface. That is on the 1st and if only one switch do nothing, and for all other switches, be it 2 or 3 etc switches under each interface add a one line command.
I have not found the correct syntax to have only the interfaces I need to be effected. For example:
interface [#FastEthernet.*#] picks all interfaces including the ones on the 1st switch which I don't want to change.
Interface [#fastEthernet[2-9].*#] ignores all interfaces.
I have tried various forms of syntax for the regular expression but either hit all interface or none.
Does anyone know how to format the request properly.
Thanks in advance
Mickey
