RME compliance issue - Check for presence of cmd "OR" cmd
It does not appear to me that I can do "OR" logic when checking commands on an interface, for example this is what I want to accomplish:
IF switchport mode access
then IF this command exist "dot1x port-control" OR this command exit "switchport port-security"
do nothing,
Else
Display the Interface Name
I best I have been able to do, is to check for the presense of both commands and a success will display one command per interface in the report and displaying both commands per interface means a failure.
I am running RME 4.1.1
1 ACCEPTED SOLUTION
Re: RME compliance issue - Check for presence of cmd "OR" cmd
You should be able to do something like this to assert the command exists:
+ [#(dot1x port-control|switchport port-security).*#]
I keep thinking of the "|" pipe in IOS.
That was it though.
I used "!Vlan", so we will check all interfaces except Vlan Interfaces.
I am able to run this on all switches in a subnet, and it works great.
Name:
Name: CheckForDot1X SubMode: No isPrerequisite: No
Ordered : No Prerequisite-Commandset : AccessPortCmdSet Parent: AccessPortCmdSet
AccessPortCmdSet SubMode: Yes isPrerequisite: Yes
Ordered : No Prerequisite-Commandset : none Parent: none
interface [#!Vlan.*#]
+ switchport mode access
thanks!
222
